Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
how to move shipping container family group up angular?
Message 1 of 32
hi
i have manipulated shipping containers group(shipping cont family+void ext. family)
i am trying to move them up angular(to ref plane)and it gives error
i read : if in family properties i have checked "worked plane based"
family -> pick new
his is no working for me
any ideas please?
thanks a lot
Accepted solutions (4)
Replies (31)
Message 2 of 32
Draw a Ref. Plane at the angle you want, name it and host the container that that named Ref. Plane (via Edit Workplane).
Message 3 of 32
There are bunch of shipping containers and void wxtrusion family gathered as group.
How to move them all up angular?
Message 4 of 32
You can't doing it without breaking up your groups of nested groups within nested groups.
By the way, you know that nested groups are problematic and recommended not to do.
Message 5 of 32
this is so complicated...
i must be another way
shipping container is cut with void when loaded
please help what to do?
Message 6 of 32
Actually there is another way, but it will require some work.  You need to nest the family three-deep to be able to revolve the host about an 3-Point axis.  It's pretty sophisticated modeling. Requires creating, manipulating and associating parameters so all nested families communicate on the same page.  I have a few families I've built like this. One in particular is light-weight concrete shake roof tiles   Took some time to get it prefect.
I'd post my inspiration for it here, but I can no longer find and download @Alfredo_Medina top blog of all time  -- the one about rotating a Pencil revolving about a 3 Axis.  Bummer.  Maybe @Alfredo_Medina is being  a little more selective about who he lets use it? Fingers crossed that he lets you. Knowing how much it helped me, I would gladly pay to own a copy.
Message 7 of 32
Corsten.Au
Hello
As of now you have a Group within group..
try not to have nested group ..
secondly use " disjoin" while moving, rotating the group,
only then it will disregard its association with plane / levels etc and allow
a smooth transition..
Disjoin ( master few skills of dis joining,unconstrain, etc )Disjoin ( master few skills of dis joining,unconstrain, etc )
Corsten
Building Designer
Message 8 of 32
Here...every elements is now hosted to the FRF5 Ref. Plane. All you you have to do, is rearrange the furniture.
Message 9 of 32
thanks, its exactly what i needed
but when i try to do the same(first ungrouped all then create one group only-> rotate disjoint is checked) it didn't worked for me
what am i am doing wrong? please
Message 10 of 32
@Ganash: DISJOIN??? you were able to rotate it off its axis by Disjoining??? That doesn't make any sense. How did you manage that?
Message 11 of 32
Corsten.Au
Work in 3d and elevation two views next to each other so you know what exactly going on.
Then ungroup them leaving only one group..
And rotate using unjoin..
Test it.. that’s how I did it ..
Corsten
Building Designer
Message 12 of 32
Corsten.Au
Give it a go and you can also do it..
Any element : group which contains elements which are level or plane based won’t rotate unless unjoined or unconstrained..
Corsten
Building Designer
Message 13 of 32
He wants to rotate the canisters in a diagonal z direction  in ELEVATION VIEW to align with a named Ref. Plane he has in that view.  Not Rotate it about its x and y axis.
Message 14 of 32
Corsten.Au
How come he mentioned “ thanks, its exactly what i needed” in replying me ??
Corsten
Building Designer
Message 15 of 32
FAIR59
all the families in the group need to be Work Plane-Based and not Always vertical.
Change those values for the family [ edgeProfileTop ] and it should work
Message 16 of 32
after ungrouped all i cant find any joined elements
then i make only one ga1.jpga1.jpga2.jpga2.jpgroup
and i still not works for me
what did i do wrong?
please help me
Message 17 of 32
I have now Idea, buddy, But, I suggested that at the very beginning , but after examining, I found that it didn't work because of the nature of the family.  But, now you say it does work.  I would just like to know what your secret to success was. Care to share?
Message 18 of 32
so i unchecked "edgeProfileTop" always vertical as suggested
and then the solution above worked
thanks you all
you have saved me!
Message 19 of 32
All I can say is that I got f'ing robbed here. If any of you guys care to look back on this thread, you'll clearly see that you are day late and a dollar short -- that I gave the EXACT same solution above!  Including a Revit file!
Thanks for the thorough waste of time.  Don't let the door hit you in the buttocks on the way out.
Message 20 of 32
i saw your file you uploaded...
see my problem was that they all messed up because  "pick new... to reference"  doesn't move them all together
and this is exactly he problem...
the solution make them move all together
is your solution just rotate or use a ref plane? it seems to have ref...
and this is not what i was looking for
please correct me if i am wrong
and of course thank you for your reply
