How to modeling Ropes in REVIT
7 REPLIES 7
Message 1 of 8
4398 Views, 7 Replies
Dear All,
I would like to ask for an advice.
1) I would like to model a parametric family of a pulley system with steel ropes (see an example in attachment). I started to model the rope as steel collums and beam (with round crossection) and than move it to the right spot where it looks like it is connected to the pulley. But the work with these is not very good and it also is difficult once there is a slight movement of the axes (the beam axis isn't 100 perpendicular).
Did anybody try to do some similar thing but in a better way? I would much appretiate any tips you might give.
2) What I also want to see is to make revit show me a big cross at the center of the rope when I cut it in any section. I did not figure out how to make it automaticaly and I habe to draw the cros by hand (with a detail line). Does anybody know a better way?
Thank you.
Vojtech
Tags (2)
7 REPLIES 7
Message 2 of 8
Sahay_R
No attachment!
Try a Sweep - with a circular cross section.
FWIW - I would really not use Revit for modeling a pulley with ropes. 3DS Max, or possibly Inventor would be a better option. Beter control and more options to create complex geometry.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 8
Sounds like what a generic model should do.  Can you share an image?
Message 4 of 8
in reply to: ToanDN
Hi, sorry. now there should be a picture. What I also tried is to create an adaptive family with 2 insertion points (attachment). But that still means that I have to move the points everytime when I move my pulley. Is there a way to create a system that would be a bit more inteligent? Have you any tips for my 2) point? How to show a big cross if I cut the rope?
Thanks a lot for any insight. Vojtech
Message 5 of 8
See attached file for an idea to control the pulley parametrically.  For the cross symbol, I would just draw two detail lines on the plan of the pulley family for the vertical segment and on an elevation for the horizontal segment, or create a detail family with two detail lines and nested it the pulley family.
https://knowledge.autodesk.com/community/screencast/2ff27316-eac1-45ac-87ea-5bf99bde77ac
Message 6 of 8
in reply to: ToanDN
1) Thanks for the effort ToanDN but I still don't see a solution to my problem. I really need it to work in 3D.
2) The ropes in the system are not 100% horizontal or vertikal so if I draw a detail line in one section it won't show me the line on the right place when I cut it with another section.
Message 7 of 8
It works in 3d. I was only demonstrating the idea how to constrain the parameters. Replace the model lines and circles woyh 3d elements an they work the same.
Message 8 of 8
