Detail Line weights not reflecting changes in Floor plan view
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
3140 Aufrufe, 2 Antworten
I am trying to create a custom detail line, but the changes to the line weights are not showing up in my floor plan view. I need a wide solid red detail line. I have changed all the setting in Manage/Additional Settings/line weights/
Line weight set to 16 (16 = 5.000"), Line color = red, line pattern = Solid. However after applying all of these changes, the lines I draw are still appearing as thin lines. Revit does change the color to what I have it set to, but not the line weight. Any suggestions would be very helpful. Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Is the view scale one in the line weight scale list?  Is Thin Line (TL) on?  Did you create a Line style that use the #16 line weight?
Nachricht 3 von 3
als Antwort auf: ToanDN
Thank you! TL worked and now I am able to see my very thick red detail line.
