How to manage large revit links?
sascari
sascari
I have multiple building linked Revit files, with each having their own nested links attached. For the most part there are no issues, but sometimes I hove to use views that encompass all the links (total of 6 individual Revit model links) and everything comes to a grinding halt. I have as many worksets turned off as possible, as many components turned off in Visibility Graphics as I can (Ie furniture, entourage, lighting fixtures, etc) but still no success. Any suggestions welcome. Thanks.
L.Maas
You have to do some troubleshooting to see if you can improve it.
-Check if it is an issue is one or more linked files. Add the links one by one to the view and see if it is related to a particular linked file.
-Load the linked files standalone and see how they perform.
-Load the links in a different (new and clean) project and see how it performs.
-What about the sizes of the linked files (and the total size)? Might be a memory issue.
-Does it help when using cropped views/section boxes/scope boxes?
-Enough space on your hard drive?
-What happens on a different computer?
Louis
Please mention Revit version, especially when uploading Revit files.
Close worksets >< Turn off worksets. The former is better for performance.
sascari
@L.Maas Yes to all those as already verified. The file sizes are indeed pretty large but I don't know that there is anything that can be done about that. I am running a machine with an i7/quadro  P600 and 16gb RAM. The links are consultant files on BIM 360.
@ToanDN Yea. I've minimized the worksets to the essential ones and that has indeed helped somewhat. Not sure what else can be done at this point. I wish there was some kind of simplify function for plan views that just reduced the load (like a flat 2d version of the model - is't that the point of a plan view after all)
16 GB is too little for any projects bigger than a house. Try 64.
sascari
@ToanDN  I wasn't aware that Revit ate so much RAM. This is very helpful. Thanks. Yea, we have six multi-story buildings living on one campus so that's likely the culprit. I just gotta download some ram now.
Thanks.
