how to make stair middle suport
BIM_Dreamer
Message 1 of 14
BIM_Dreamer
how to make stair middle support under the thread/step. thank you.
Replies (13)
Message 2 of 14
Switch on the middle support.
Message 3 of 14
BIM_Dreamer
That is already a middle support. My question is how to make the middle support to be underside of the steps. Thanks
Message 4 of 14
Use a carriage type for the mid suppport.
Message 5 of 14
Look to me like the Tread Profile is the problem (e.g. drawn incorrectly in relationship the Origin Ref. Plane).  Does it happen like this when you use the Default Profile?
Message 6 of 14
Like this?
Message 7 of 14
Does your screenshot depict what you are trying to achieve? Looks like you want the top of stringer on the same plane as the top of the treads.  In other words, the treads would be fastened to the side of the stringer as shown.
Message 8 of 14
BIM_Dreamer
it's already used carriage. thank you
Message 9 of 14
BIM_Dreamer
managed to get the stringer to underside of steps by editing the tread profile moving above the reference line. thank you
Message 10 of 14
BIM_Dreamer
don't mind to share with this configuration. thank you
Message 11 of 14
The top of tread profile is on the reference line. The tread thickness under the stair run configuration is set to equal to the height of the tread profile. The carriage will match to the bottom the treads automatically.
Message 12 of 14
BIM_Dreamer
don't mind to show me where is it, because right not now the stringer and steps don't align each other i have still 1mm gap. thanks
Message 13 of 14
zeynep3KLJ6
This is great! How about the stair landing support?
Message 14 of 14
Model in place or beams.
