How to make section name appear top not bottom?
martins.logins2
Message 1 of 9
martins.logins2
The name of section appears at bottom but I'd like to figure out how to make it appear at top. Thanks
I click to create nameI click to create nameIt appears bottom but I want it to appear at topIt appears bottom but I want it to appear at top
Replies (8)
Message 2 of 9
_Vijay
Do you mean the detail name?
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 9
martins.logins2
Yes, believe so
Message 4 of 9
bimscape
Just click (once) on the view (ie the section in this case) on the sheet- to select it. And with it selected, you can now drag the name (called the "View Title") up to the position you want.
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Message 5 of 9
martins.logins2
That's what I am usually doing and that takes extra unnecessery time. I was thinking how to make is a defualt when click it shows on top not bottom
Message 6 of 9
bimscape
Would love to be proved wrong- but I think it's position is hard-coded in.
Kind regards,
Ian
Message 7 of 9
lucdoucet_msdl
@_Vijay
Do you mean View Title Marks?  😜
-luc
Message 8 of 9
_Vijay
@martins.logins2  you need to move manually. There is other no others shartcut for this task. It's Revit API limitation.
Vijayakumar
Head of BIM
Message 9 of 9
amarkonathala
#1. Select the View title
#2. Move to Location Wherever U want
