How to make roof editable
A roof was imported to Revit as a single uneditable element (I dont have info where from). It has a very complex shape with a lot of curve points. When I double click on it, there is no options to change anything other than "finish model" or "cancel model". What are the ways to make it editable (to change pattern for example etc.) Is it through mass creation? If so how can it be done, since there would be needed millions of reference planes. Is it through Dynamo/Grasshopper implementation? Thanks!
martijn_pater
Which roof? what shape? how many curve points? double click what? ways to make what editable? Use mass creation for what?... You get the point:)…  add the file (or an image at least)...
You won't be able to edit the geometry in Revit - you will need to determine the original software package and edit it there.  To change the materials, you can go to Object Styles and look at imported categories.  Find the import and set the materials.
L.Maas
You imported something from other software. This means Revit will treat this as a static object. Depending on how the object was modeled/exported you might be able to change the material but that is as far as modifications can go within native Revit. You could try to recreate the roof with massing tools. then it is a native Revit element and can be changed as you like
Depending on what the roof is exactly, Dynamo might be able to modify it.
It might be best to go back to the creator of the roof an see if he can make modifications as needed
Louis
Please mention Revit version, especially when uploading Revit files.
hmunsell
please post the model, or at least the roof portion of the model, so we can look at it.
Howard Munsell
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
