Revit 2019 - IFC Not working/Freezes
I have a small problem regarding IFC exporting.
I am currently using Revit 2019, and have installed the correct IFC 2019 Plug-in. When clicking on the File Menu and then Export to IFC my screen/Revit suddenly freezes. The program becomes unresponsive and the IFC Export option does not open with the options before exporting.
Is there maybe something in the settings, or maybe a plug-in that could be causing this?
Thank you in advance for the help.
L.Maas
You should be able to export IFC without any add-ins. It might be that (other) add-ins cause a conflict. Consider removing add-ins and see if then works
Louis
Please mention Revit version, especially when uploading Revit files.
Thank you for your help!
From all the things I tried, I did not think of Un-installing the IFC Exporter entirely.
Thank you very much for your quick response and solution to the problem.
