How to make L shaped corner curtain wall panel in Revit
Message 1 of 11
Hi Everyone,
Recently I have a problem and here is the picture. I want to create the family of this corner panel D-A-9 but I dont know how to do it.  It is noticed that this is a panel actually not the corner mullion.  Also, I am quite interested in how to let this in place using curtain systems. Could you please help me? Thank you very much. 578967533.jpg
Replies (10)
Message 2 of 11
 Model In-Place.
Message 3 of 11
dzanta
Start with the Storefront wall type.
User the "L Corner Mullion 5" x 5" Corner" Mullion for the border mullion
Click Edit Type and duplicate
Change material to Glass
Change thickness to match thickness of panel (i.e. 1")
Change offset to align panels faces
See image attached.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 4 of 11
David_Knight
Yep.  Model that whole corner piece.  Then just but your storefront standard pieces into it.
Message 5 of 11
David_Knight
this method doesn't account for a top, bottom, or middle mullion which it surely will have.
Message 6 of 11
dzanta
I didn't realize your issue was for horizontal mullions too.  From the picture, it looked like you just needed help on a vertical corner mullion situation.
For the horizontal mullions, what shape is the horizontal mullion?  You can create a custom mullion profile and use this within the Type Properties of the curtain wall.
Watch this video to learn about how to modify curtain walls and profiles:
https://www.youtube.com/watch?v=aKreV7BBSSQ
Message 7 of 11
You can TAB select the panels and edit in place to miter them.  Screencast in a few minute.
Message 8 of 11
This is what I was thinking  because the OP said "this is a panel actually not the corner mullion".
Message 9 of 11
Yes, this is exactly what I am saying. I know the model in place or void cutting is a solution but I just want to know is there some way that we can model this in a family? So it is possible to extract some useful information from it such as surface area and generate the schedules for the whole building.
Message 10 of 11
You can create a panel family with a mitered end and a proper setback distance so that when you replace the two corner panels with the panel family, they miter properly.  Then you can schedule them normally.  Another option is Paint the surfaces you want to schedule and filter a material take-off schedule using As Paint field, that way you can use either a model in place L shaped panel, or system panels edited in place as shown in my screencast, or even thin L glass walls.
Message 11 of 11
You can label dimensions with shared parameters in an in-place component just as you'd do in a loadable component. And you can include formula-driven parameters (e.g. Volume=Length*Height*Thickness or, Area=Length*Height).
