Filled region for Mullion Profiles
2 ANTWORTEN 2
Nachricht 1 von 3
309 Aufrufe, 2 Antworten
Are there any options to have a filled region in the family of Mullion profiles or any other profiles produced in Revit?
as shown in the file attached, I want to see the mullion in gray (not to be transparent), and sketch a filled region in gray in its own family.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Hsve you tried to nest a detail family inside the profile family? Or, set the curtain mullion cut pattern to solid gray from the object styles?
Nachricht 3 von 3
Yes, as @ToanDN says, you can override cut pattern -- by element or category.  Easy, breezy.   Are you not able too?
