How to make continous spiral floor
HeadbuttJ
HeadbuttJ
I am trying to make a spiral floor. I used model line to draw the outlines and used modify sub-elements to level up one end of the floor. I planned to copy it to every level. But I cannot make the floor continous due to line duplication, I have to make a crack on the floor, but by doing so the stair is not continous. Please find my attached file and video. Any idea? Thanks!
syman2000
You have to do half arc and you can do spiral.
Do you have Modify Sub-Elements? If so, create half-circle Ramp, use Modify Sub Elements to change the end elevation, and Clipboard Copy/Paste Aligned to Level above and Mirror.  Then select both halve-circles and Clipboard Copy/Paste Aligned to every-other Level.
