How to make a wall attach bottom base?
Hello, I want walls to connect to the roof under it like in the Attach Top Base command. Is there a command like Attach Bottom Base? How can I get the wall to end on the roof?
JuanYusta
Hi @mehmetzahidc
It's posible with the same Attach top/base option. You only need to change top for base in the up ribbon.
Thank you so much. Problem solved.
Another method is to draw a Reference Plane in Elevation and select that RP as the Attach Top/Base Target for the Wall.
shane_v
Very nice
