Triangles prints out as boxes
bb
bb
I have been having trouble printin out my drawings. All the fill patterns that are slobed/triangular seem to print out as boxes.
In my model they look like this:
but when i print them out they change shape:
I have tried diffrent "printers" and scales/resolutions
I´m running Revit 2021.1.1 on a Microsoft Surface book 3 with Windows 10 pro 64 bit
syman2000
Do you print to PDF and get the same result?
Maybe this?
Revit - Diagonal lines print jagged in pdf and physical printer | Revit Products | Autodesk Knowledg...
But your screen one is also funky looking. Does Smooth Lines with Anti-Aliasing affect it's appearance?
Smooth Lines with Anti-Aliasing | Revit Products | Autodesk Knowledge Network
Hey I hope you found a solution to your problem.
I was looking for information on this forum for how well Revit works with Surface Book 3 and I found this thread.
Would you please describe your experience with surface book 3 using Revit? Does it get heated? Is the processor and graphic card sufficient for everyday Revit usage? I really like the portability of surface book 3 and would like to have a laptop that I can take on site visits etc but I use Revit for all my Architectural projects and other autodesk programs like Autocad and 3dsMax. So I need to make sure SB 3 is good for those. From the internet articles I read it seems like it's one of the best but I'm reading some negative reviews on forums like Revit.
Please help!
