How to make a door handle relative to the top corner of a parametric door?
Message 1 of 16
I've produced a very basic cabinet door that retains an 85mm wide border as the height and width is adjusted. I now want to add a handle which stays the same distance from the left hand edge and from the top edge regardless of the door size. Revit doesn't seem to like having these two constraints even though they don't contradict each other, is there a way round this?
Replies (15)
Message 2 of 16
Sahay_R
Constrain the handle by dimensions, and then lock them.
Is the handle a nested family? If not, I would bring it in as a nested family. Nested families are easier to control than local geometry.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 16
Thanks for the reply. It is a nested family, would you suggest locking it to a reference plane which is then dimensionally locked or locking the nested family itself to a dimension?
Message 4 of 16
Sahay_R
Align and lock the nested family to a reference plane. Also make sure that the reference plane is constrained to the edge of the door by a locked dimension. That should keep it in place.
Rina Sahay
Message 5 of 16
That was my original approach but Revit doesn't seem to allow two points of constraint, the error I get is attached as a screen shot. If I try to change the width it still behaves correctly but it won't allow me to change the height once the top of the handle is locked to a reference plane as well.
Message 6 of 16
Sahay_R
Please take a look at the attached family.
All else failing, please share the family.
Note - the handle is just a plain extrusion, not nested.
Rina Sahay
Message 7 of 16
Thanks for taking the time to put that together. The height parameter works as I would want it to and I can replicate that in my own project, however I'd like to be able to change the width as well as the height and the handle maintain its relative position.
Message 8 of 16
Sahay_R
Can you share the family, please?
Rina Sahay
Message 9 of 16
Watch the screencast below:
Message 10 of 16
I've attached the family here, thank you both for all your help so far!  The steps I've followed are very similar to those shown in the screen cast, the only differences I can think of which may be causing the problem is that my nested family for the handle isn't face based and that my height and width parameters are instance based rather than type.
My family will flex in width but not in height.
Message 11 of 16
Face based family make it a little easier but it s not critical. You can place a non host family on a reference plane or face in a similar manner. Instance to type parameters are also not critical in terms of constraining the family. But it is more logical to use type parameters for this kind of items.
I cannot open your file now but can take a look at it tomorrow, unless someone else gets to it sooner.
Message 12 of 16
chrisplyler
Oh no, we're all going to wait for you now. I'm going to hold my breath. Starting now. No, wait...starting...NOW! No, wait...
Message 13 of 16
Sahay_R
....and in the meantime we watch @chrisplyler go blue in teh face.....
Rina Sahay
Message 14 of 16
Sahay_R
@Anonymous
Take a look at the attached file. It works - the handle now behaves like a well trained German Shepherd.
Rina Sahay
Message 15 of 16
Thank you, that's perfect! Do you mind explaining the changes you made?
Message 16 of 16
Sahay_R
In the handle family -
1) added invisible lines to the reference planes and locked them in place
2) inserted this family was inserted in the project, the invisible lines were recognized and  available to be locked in position to the reference lines.
Rina Sahay
