Hello, I'm working with Revit and trying to apply Mechanical Equipment (in the Systems section). and when I click on that I get a message: Mechanical Equipment family is loaded. And as far as I know there is a basic package that should come with the software. How and where can I get the basic package that should come with the software?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Help]
Solved by ToanDN. Go to Solution.
Solved by barthbradley. Go to Solution.
Insert Autodesk Family button on Insert ribbon. Or download and install content from: https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
Hi @alonitzan007
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Thank you for all your help. right now I'm trying to download the "US English Content v1 for Revit 2024". Hope that it will work 🙂
