How to keep Swept Blend's prfiles Vertical ??
000853959
Message 1 of 16
000853959
Hello Folks:
when creating Swept Blend..
How Can you keep Swept Blend profiles vertical but not perpendicular to the path?? any suggestions?
Pleas see the image Screenshot 2024-05-31 155810.pngScreenshot 2024-05-31 155810.png
Replies (15)
Message 2 of 16
Huh?
Got a picture of what you want to model in Revit?
Message 3 of 16
000853959
I already attached the image I just need the profiles as shown in the picture, any idea please?
Message 4 of 16
I want to see a photograph of the architectural feature (or whatever it is) that you are trying to model in Revit with a sweep. I don't understand your written description or screenshot.  Doesn't look like anybody else does either, since you've had no responses.
Message 5 of 16
Use an adaptive generic model family with nested profile families that are set to be always vertical.
Message 6 of 16
Maybe this is what you are after?
Message 7 of 16
Oops. You said Sweep Blend. Not Sweep. My bad.
Vertical VS Perpendicular:
Vertical AND Perpendicular - just for fun:
Message 8 of 16
000853959
Iam trying to model Ramp with inverted beams on both sides as shown in the picture, I need the family category to be "Structural framing" so I can host rebar, However I need the profile of the swept blend to be perpendicular to the Ground, I dont have an option to control the angle between profile and ground. sorry I know my language is not that good I hope I could explain my point
All options grayed out except first one! why?!
Message 9 of 16
000853959
it might be a solution but not long term especially if you want to modify the model, it would waste much time, thank you though
Message 10 of 16
000853959
How come your profiles here (in the picture you attached for swept blend ) are not perpendicular to the Path??
Message 11 of 16
in the real world, a beam running along the underside of a ramp (e.g. at an angle to ground level) does not remain perpendicular to the level ground below. That doesn't even make sense.   That's why I asked to see a photograph.
Also, why are you using a SWEEP BLEND?
FWIW:
Message 12 of 16
000853959
Message 13 of 16
000853959
Can you model this?
Message 14 of 16
Sure. I would cut the ends vertically and perpendicular to ground.  Bada bing.
Post your file here.
Message 15 of 16
- Start a swept blend
- Draw the path using one spline on the level
- Draw the start profile at starting point of the spline
- Draw the end profile at end point of the profile move it vertically
(if you use a loaded profile family then you can simply set Vertical offset from properties)
Message 16 of 16
000853959
Perfect! thank you, copy the profile and Offset from the prfile it self, simple! thanks dude
I've been picking the the path instead, that was my mistake
