How to install the Rendering library? Revit 2022
I installed the 2022 Revit version and I got this message:
Rendering features are currently disabled.
You  must install the Rendering library to use rendering features.
The autodesk support for this really didn't explain anything, where exactly can I find the rendering library to install?
In their "solution" they say I have to Start the Revit installation program and proceed to the Install > Configure Installation page, but I have no idea of what is this installation program or where I can find it.
RDAOU
@Anonymous
2022 is installed without content libraries... these are installed separately...then from file menu >> options >> you need to make sure the location of the contents/assets required for rendering is added
see link below
https://knowledge.autodesk.com/support/revit/downloads/caas/downloads/content/autodesk-revit-2022-content.html
joe_aylward
I have got the same problem and I can't sort it out.
The content 2022 are installed but not the Material Library.
Do you have other suggestion?
I'm struggling!
Thank you!
bimc32022babita
Community Visitor
Community Visitor
@RDAOU which file menu are you talking about? Please mention the solution clearly.
