How to insert a Revit family file into a Revit Project?
4 REPLIES 4
1811 Views, 4 Replies
I am trying to inset a family (.rfa) file into a Revit project, but have had no luck.  It is named C09-Conceptual-Mass-Finished.rfa.
How can I do this?
How can I do this?
4 REPLIES 4
Per the book's instructions you need to download it from the book's web page.
Once downloaded...Insert tab...Load Family...select the downloaded family.
I did that but nothing happened.
After you insert a family into a project, you still have to place it.  Go to the Architecture Tag and select Component and find the family in the properties window and then place.
Thank you.
Thank you.
