How to Include Floor Parameters in a Room Schedule in Revit
MooreMU
386 Vistas
4 Respuestas
Mensaje 1 de 5
MooreMU
Hi everyone,
I need to create a room schedule in Revit, but I also want to include two extra shared parameters that belong to floors. When I try using a multi-category schedule to include these parameters, I encounter an issue—Revit displays the room parameters and floor parameters separately instead of in a single row.
How can I ensure that for each room, the corresponding floor parameters appear in the same row within the schedule? Any suggestions would be greatly appreciated!
0 Me gusta
387 Vistas
4 Respuestas
Respuestas (4)
Mensaje 2 de 5
vitorbortoncello
Use floor finish parameter within rooms
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Mensaje 3 de 5
Give a common parameter (ie. Comments) of the room and the floor in the room the same value and sort by it, untick Itemize.. then they will become one row.
Mensaje 4 de 5
MooreMU
Thanks to both of you. Yes, we can do that. However, this approach requires adding an extra parameter to rooms or floors, which is not ideal—especially for large-scale projects like those using BIM.
0 Me gusta
Mensaje 5 de 5
RDAOU
@MooreMU
A Floor element are not Room aware component even if you model such floors within the boundaries of the room. The only way to do what you want is
  • Either to do it manually as suggested previously
  • Or to use Dynamo to identify floor elements within a specific room >> read their parameter and write it to the Rooms
  • Or if it is finishes related exercise, try Roombook/Areabook extension that comes with Revit
