How to include a column for "comments" in the revision schedule
Message 1 of 11
There are MARK and COMMENTS in the Properties box, but how do we include these into the revision schedule? There is no option to create a new parameter.
Replies (10)
Message 2 of 11
L.Maas
Correct. Unfortunately it is not possible to extend the revision schedule. The only possible option is to use use one of the other columns (if not all in use already) for your purposes.
Maybe good to support one of the proposals in the IDEAS forum, like THIS one.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 11
Mikael_QUIJADA
It's not possible natively but you can use this dynamo script 🙂
It's in french but change
"Nuages de révisions" by  "Revision Clouds"
"Commantaires" by "Comments"
"Nuages" by "Clouds"
You must dowload Clockwork package
Mikaël QUIJADA
Expert Revit Structure
Message 4 of 11
Hey man,
I need to get this working, for some reason I get some errors running the script you provided in dynamo, would you give a more detail workflow of this and what needs to be done before hand ?
I much appreciate it.
Message 5 of 11
Have you been able to fix this problem ?
I'm asking since I'm having the same issue with revit revision cloud.
If you have found the solution for this, please kindly share with me.
Message 6 of 11
Mikael_QUIJADA
Hi guy,
Can you give me more details abouts this errors ?
Have you dowload Clockwork package in Dynamo ?
Mikaël QUIJADA
Message 7 of 11
Thanks for the prompt response,
yes I have downloaded clockwork and dragged it into canvas in Dynamo,
This is the error I receive, as shown in the picture below,
what do I need to do to fix this ?
Iman
Message 8 of 11
Mikael_QUIJADA
Ok the problem come from clockwork.
Download Dynamo 0.9.1 > http://dyn-builds-data.s3-us-west-2.amazonaws.com/DynamoInstall0.9.1.exe on http://dynamobuilds.com/
Download clockwork package 0.9.x version.
it should work better.
Mikaël QUIJADA
Message 9 of 11
Cool, I guess it's time to start DYNAMO. Smiley Embarassed
Message 10 of 11
Hello, thanks for the tips with the export to Excel function!
I wonder - why is it necessary to include the owner views in the transposition?
Wouldn't just the number of elements and the parameter name be enough?
//Kalo
Message 11 of 11
isaac.e.hartman
Christ, this is stupid. Why include a COMMENTS section in the revision properties at all? It's purely internal? Why don't Revision Schedules just work like any other schedule in the program?
AutoDesk, if you're going to charge $5K/year for a program, how about you tie up a few of the loose threads?
