someone can say which .rft file have to opne to create a profile as in the attachement to insert in wall with extrusion?
I create this in attachment but think it's not good beaceuse when go in command extrusion of property wall, despite is insert in project, there isn't.
Thank's
Gelöst! Gehe zur Lösung
Gelöst von dzanta. Gehe zur Lösung
To use/create a profile for use in a wall:
1. Start with the Profile-reveal.rft template file to create a profile for a wall reveal. Alternatively, use the profile.rft to create any profile and specify the category/usage prior to drawing your sketch.
2. Load the profile into your project
3. Use the wall reveal command to create a new wall reveal type using your custom profile
You can also use your custom profile within the assembly of the wall as well. See the following videos that teaches you about reveals in revit....
https://www.youtube.com/watch?v=4tY9TZil1ek
https://www.youtube.com/watch?v=QY78z--fcX0
https://www.youtube.com/watch?v=e8_f56z91zk
https://www.youtube.com/watch?v=vK14ymYDdk8
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
thank's for video.
at minute 3.20 click on "portion on run", but with tab,
I can't achieve of it.
you have to place your mouse cursor on the stair assembly and tab to select it...then you can go to type properties to see the nosing profile section
When you are in the profile family, you go to "Family Parameters and Categories" so you can assign the type of category it belongs to. This allows you to schedule the profile properly as well as use it properly...
For example:
If I categories the profile as a wall reveal profile, then it can be used as a wall reveal profile within the Wall Reveal Command and within the Wall Assembly as well as scheduled in a Wall Schedule.
