Hi people,
I would like to import DWG, modells and also new categories, which comes with newly added family, as hidden. Why? Because I have many drawings and I have to go in every sigle one and manually switch that off. Even with template, newly added things are a priori shown. So that doesn't help either.
I appreciate any help, thanks
Sounds like a View Template or View Filter is controlling visibility. Have you checked that?
This list might be useful to you in this case:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Thanks for answer. I know this list and it is not what I need. My question is opposite. There is no problem finding new things, problem is that they are visible. I need them invisible, right at the point of importing. Turning them off after is super time consuming.
Same answer: View Template and/or Filter applied to View.
@Anonymous wrote:I need them invisible, right at the point of importing. Turning them off after is super time consuming.
But you need to see 'em to place 'em though. Don't you? Or, are you using the Braille Version of Revit? 😉
Is this sentence worded correctly?
Sorry, my mother language is not English. And for me that sentense is correct. Most important in contains the information that I need communicate.
Try it in your Revit. Make a template or filter. Use it on a drawing. Insert a dwg. Insert a new family with categiries, that are not already in Revit.
Can you see them in the drawing with the template? If yes, that is exactly what I don't want to.
I want that dwg to be inserted and also the visibilty of that dwg to be off. I don't need to place it manualy origin to origin is fine for me.
I don't have to place the object of the family, the categories (of that family) are added at the moment of loading the family in modell. With them I need the same thing as described above with dwg.
Last try. I send printscreens. I am using template. Those red higlighted are thing that I just added. And do you see that? They are visible, eventough I am using template. I DON'T WANT THEM VISIBLE, I WILL TURN THEM ON MYSELF. It means, they are turn on on every drawing. Is there some global setting, which makes every new imported thing automaticaly not visible?
Thank you for the patience and answers, but I thing it is not possible, that what I want.
I unchecked the box Show imported categories in this view. I deleted and inserted the dwg again. But down there at the dwg the check box is checked - automatically. That is the problem.
So what if it's checked? It's not visible in the View regardless.
Unchecking "Imported Categories" does exactly what you want. Makes "them invisible, right at the point of importing".
Now, you need to deal with this warning every time:
It is also checked in every other view. It is checked for every plan, section etc. So I don't see it in this view but if I go to another plan I will find it there visible. I can unselect that option Show imported... in every viwe, but that is not useful also. And this option Show imported categories is missing in Model categories (it is not very helpful anyway, but closest to what I need).
Most people would NOT want "Show Imported Categories in this View" unchecked by default. But hey; to each their own.
Create View Templates.
Yeah exactly, most people don't want that 😀 . Unfortunately template dosn't help. When you import something, it is added to that template with visibility check box marked on (in every template).
Never mind, thank you for all the answers 😉
The checkmark is ignored if "show imported categories in this view" is unchecked. That's why it's grayed out.
