How to hide specific furniture edge?
Hi,Im fine.and you?
I have a question to you. Please save me.
I want to hide this chair's edge.
This chair was inserted from 3DSmax
When I changed all settings from represent edge to non represent edge
all edge was hided. For example floor line.
I want to hide only chair's edge. please reply me with your answers.
please forgive my cheap English. Thanks.
RobDraw
Show us what you want and share the family.
Rob
ahmadfiroozi000
I think if you load it in a family then insert it into the project your problem will solve.
syman2000
You can hide edge in 3dsmax and export that hidden edge to DXF. In Revit when you import the object, that object will display as hidden line and only show outline of the object without the 3d mesh.
https://www.revitforum.org/showthread.php/4649-From-3ds-max-to-revit-without-viewing-triangles-edges
kh_jea
Don't use/insert overly detailled or complex families from 3DSMax or AutoCAD.
Simple Revit families will look a lot cleaner and won't bloat your project file.
