- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As the title states, is there a better way to handle this situation?
Here's a scenario: I have a client that only wants brick on the front of their house. All of the other sides of the walls will have horizontal siding on them. At the corners where the brick exterior and the siding exterior meet, Revit doesn't handle this situation correctly. The horizontal siding will usually just wrap to the front of the house. This is a problem because I want 4 inches of brick to show on the side elevations to show the brick thickness. Alternatively, I understand that you can have the brick wrap the ends of the wall however that will wrap the brick for the entire thickness of the wall. For this example I have a wall type made that shows 4 inches of frame wall and 4 inches of brick as the exterior finish. The brick will wrap the full 8 inches on the side which I don't want to happen. So far I only have one fix for this issue and it's to create an in-place-wall at the end. I usually just give the in-place-wall a small thickness and assign it the brick material. This takes extra time and it's something I feel that Revit should be able to handle without me having the make a workaround. Surely they know that we may want to connect walls with different exterior materials. Is there a better way to handle this situation or am I stuck with my workaround until Autodesk adds the functionality?
