Linework in Details - Cut Profile Lines - Help
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
pix18001
626 Aufrufe, 5 Antworten
I'm working a a detail drawing. In the detail I used the cut profile function to make the detail look right. However, when I use the linework tool to change the weight of the line I cannot select the profile lines. Any thoughts on how to override?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: pix18001
Cut profiles are considered detailing and Linework tool only works on model elements.  You can use detail components and detail lines to furnish detail views when the two options above don't suffice.
Nachricht 3 von 6
pix18001
als Antwort auf: ToanDN
I understand most of what you said. Could you possibly give an example of how to drop the line weights down?
Nachricht 4 von 6
pix18001
Having the same problem with this detail component.
Nachricht 5 von 6
As I already set, you cannot use Cut Profile on anything but model elements.  To change lineweight of a detail component, draw the detail lines (or region boundary lines) using different subcategories and assign different lineweights to them.
Nachricht 6 von 6
pix18001
Got it. Thanks. :daumen_hoch:
