How to give angular dimension above 180 degree
chandrakant_arya
chandrakant_arya
I am giving angular dimension to element, and it is more than 180 degree so instead of showing 190 degree it's giving me 170 degree pls let me know if you guys have any way to sort this thing out.
Accepted solutions (3)
handjonathan
Hi @chandrakant_arya
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
chandrakant_arya
Hey, thanks for the solution @barthbradley but can you give more simple way because the way you showed in the video, I can't understand that, but thanks for the support and prompt reply.
Mike.FORM
This is what the video is showing.
chandrakant_arya
Thanks @Mike.FORM.
