How to export sketchup model as mass in revit?
Message 1 of 15
Is it possible?Can you can also use massing tool like these
mass.PNGCapturedvdv.PNGOne the imported sketchup model.
Replies (14)
Message 2 of 15
aRcHiTeCt.JM
...THE EASY WAY TO IMPORT A SKETCHUP MODEL INTO REVIT
http://bimtobrilliant.com/the-easy-way-to-import-a-sketchup-model-into-revit/
....Limitations of SketchUp Data Imported to Revit
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
....Import SketchUp Files
.... Creating a Revit mass from a SketchUp mesh
https://www.linkedin.com/learning/sketchup-revit-workflow/creating-a-revit-mass-from-a-sketchup-mesh
.... 12 tips for conceptual massing
http://www.extensionmedia.com/basecamp/1289422/augiaecedgesummerseptemberissue/BOWLES_12TIPS_v1.pdf
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 15
There are 2 problems .
One is that the exported file is in dark grey color
The other problem is floor mass tool doesn't create any floor mass in the model although rest of the massing tools like walls/roof/curtain wall are working fine.
Message 4 of 15
The other problem is floor mass tool doesn't create any floor mass in the model although rest of the massing tools like walls/roof/curtain wall are working fine with the sketchup mass model.Formit model with water tight issue also have this problem.
Message 5 of 15
aRcHiTeCt.JM
... this bed was made in sketchup
... then exported as a dwg
(to do that you need to separate all elements in different dwg and apply same material for each one)
... then create a family in REVIT
... look how good it renders in REVIT
... to me is almost perfect
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 6 of 15
Post your sketchup file.
Message 7 of 15
Do you have Levels intersecting the Mass?  If not; there's your problem.
Message 8 of 15
Yes there are levels intersecting the model.This problems doesn't happen with other mass object  made in the project.
This only happening with sketchup imported files or Formit files that have water tight issues.
Message 9 of 15
I don't know what you mean by "water tight issues".  But, like I said: post your Sketchup file and we'll take a  look at it, and see if we can find a solution for you.
Message 10 of 15
Here is it.
Message 11 of 15
Is this a joke?
Message 12 of 15
aRcHiTeCt.JM
.... I don't know what is worse
...  the "model" .... or the version it was made
Edited by
Discussion_Admin
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 13 of 15
Message 14 of 15
I forgot to mention that revit would give this error if I open sketchup file from versions 14-18 .
For some reason if I save the file  as version 8 or below version than it doesn't give this error.
Message 15 of 15
I had no problem importing it into a Mass Environment.  And no problem making Curtain Wall Systems or Mass Floors from it.  See image I posted.
