How to Explode An AutoCAD 3D Model in Revit Architecture?
darshan_m_athnur
darshan_m_athnur
Please assist me with the problem I'm experiencing.
jay_colcombe
If you select the IMPORTED File/Model in the Contextual Tab in the Ribbon there will be an option to explode geometry.  This may not work for all 3D CAD models!
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-F2D2B53E-187A-446D-8316-D7C2C35048E1
Jay Colcombe
Autodesk Certified Instructor
darshan_m_athnur
I imported the file and tried to Explode it, there's an error notification popping out sir. As you can see in the attachment. Now what to do next, Sir?
jay_colcombe
I thought this nay be the case, some 3D Cad files cannot be exploded.
A common solution for 3D CAD files that down cut or display correctly is to import each CAD into its own Generic Model family.
Create a New Generic Model Family
Insert the 3D Cad file
Save and then Insert the Generic Model Family into the Revit Project
you can Explode a 3D CAD Model in the Family Editor as per the link above
Jay Colcombe
darshan_m_athnur
Ok sir, I'll try once if not revert you back on the same.
Thank you.
