When exporting sheets to PDF directly from Revit, I have observed that joined elements with the same color override have brighter outlines. Geometric elements are joined. These elements are created using different tools, such as floors or masked regions. I initially thought this might be the issue, but even between just floors, the problem persists.
You can see the issue in the PDF view below:
And here's how it appears in Revit:
Is there a specific setting that needs to be turned off or a visibility override that should be included to address this? Thank you in advance for your assistance.
