06:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hello
i need a little help
1.when i insert concrete beam there are lines in the floor plan surface.
how to clean that so i can render the interior without that lines ? i want another way not just raise the floor on top of the concrete beam.
2. when i insert wall there is overlap between wall and concrete beam. so whe i make section. beam section looks like overlap wit wall... so
is it right i put wall in the centre of beam or what should i do so i cam make good section between wall and concrete beam.
Or should i use differente template between architectural template and structure template... in revit ?
thank you
