how to eq a shape to an adaptive point
Message 1 of 11
i'm trying to make a "tree" that has adaptive points. the basic shape of the tree is a rectangle and i want each rectangle's center to be the point.
when i make an instance parameter and change the number to bigger or smaller, it doesn't  originate from the middle point that i need- that is the reference point.
attaching pics- can see that the first width is 30, then when i try to change it to 60, it expands not from the middle.
important to say is that i don't have the eq sign when drawing the rectangle.
when i draw the rectangle,i start from the middle point and go up(half the length i need) and than right(half width that i need) and than continue with the regular lengths so the rectangle will be the right size from beginning and will be centered.
Replies (10)
Message 2 of 11
martijn_pater
I'm not entirely sure what you're trying to do, but I think the answer is nesting of another adaptive family...
Message 3 of 11
What prevents you from placing eq eq dim to the point.
Message 4 of 11
What about hosting Reference Points to Work Planes of other Reference Points and driving their Offsets through Parameters?
Check out Message #4 and its attachments:
https://forums.autodesk.com/t5/revit-architecture-forum/generic-model-attic-steel-sheets-full-parame...
Message 5 of 11
eq sign doesn't appear.
i could do 2 dims and then i'd have the eq option.
thing is if i do 2 dims, that means it'll be 2 different instance type parameters, i think.
i just gave up on the perfectionism in this case and did the points as revit wants it, from an edge and expands towards the right/ left and not from center wise.
Message 6 of 11
May I ask why you think building a tree as a generic adaptive family is a good idea?
Message 7 of 11
i have beams that are under a floor(hidden in pic) and from their edges i need something i can control- the branches attach to the beam(to the sphere at the edge of the beam) and then the other edge of that branch i can move around and place them on intersections of the mass. each branch is a different length too, a bit longer/ shorter.
look at the picture below, hope that explains it.
if you have any other ideas, i'll gladly read them! i've been only learning from these posts. 
Message 8 of 11
martijn_pater
😅I have no idea what you're trying to make... maybe post some more plans/sections/3d etc, elaborate some more...
Message 9 of 11
@martijn_pater
this is a studio project i'm doing in uni.
a is a beam holding a floor. b is a sphere that's attached to the beam from both edges. c are "legs/ branches" that are attached to d- intersection of pattern based family.
beam and sphere (a+b) are built in one family.
c is an adaptive family so i could move the edges around when i see where the intersection (d) is and place it there.
any ideas that are smarter than mine?
Message 10 of 11
solution received from the link below:
https://www.youtube.com/watch?v=YOxNKu76rx8&t=2s
Message 11 of 11
martijn_pater
@AnonymousWell I don't know the ins and outs ofcourse, but I think I would look at keeping these two constructions seperate with a ring / triangular truss maybe in its design. Just a thought though, probably you have a project supervisor to help you along... Regarding the adaptive family question, it seems you've found the answer.
