How to edit Seciton Boxes
nataldom
nataldom
Community Visitor
Community Visitor
Is there any way to edit the section box boundary? I have a section cut that looks like this:
( cuts the model like ---|___> this )
And if not, is there a way to create two section boxes at the same time in the model?
jay_colc
You cannot Split or Create Multiple in one action for Section Boxes but you could just Duplicate Views - You can in a 3D View > Right Click the View Cube > Orient to a View and edit the Section Box Handles
Note! In most instances the Section Box is Hidden in the View
Jay Colcombe
Autodesk Certified Instructor
syman2000
If you have setup section, you can set the 3d section box to follow the section cut. Click on the triangle icon and go to orient to view and choose which view you want the 3d view to follow.
You can rotate the box.
