HOW TO delete them
HOW TO delete them
Message 1 of 8
HOW TO delete them
hi .. i'm working at revit mep project
i link the file and make alot of what want to do
but i want to make this small random lines to disappear
Replies (7)
Message 2 of 8
Avaris.
It is a hatch, you could for example manually override it in the linked file. Or change the material.
Another option is to make an override in the host file for all floors in your linked file. There are infinite options to solve it. More or less.
Message 3 of 8
can you say to me the steps please
Message 4 of 8
Avaris.
Message 5 of 8
yes
i want to make the hvac system at this view
and going to v/g and can't find the fill pattern option to unchecked it
Message 6 of 8
VV....Floors....Projection/Surface column click in the pattern box and uncheck the "visible" box for Pattern Overrides.  You don't have to open the linked model at all.
Message 7 of 8
RobDraw
Yes, the surface pattern for floors can be turned off, but where you do it will depend on the Visibility Graphics settings for the Revit links in the view (template).
Control over the visibility graphics for linked files can be done in many places depending on the VG settings for the link, which can have priority over other settings. Knowing these settings will tell you where to go to turn them off. It could be the object styles for the project, the view template for the view, the V/G overrides for the view, or the V/G overrides for the Revit Links in the view. There may be other ways, too.
The view settings for the link can be found here:
Rob
Message 8 of 8
