How to create textures on wall?
HeadbuttJ
HeadbuttJ
Is there any way I can create textures that can really have light and shadow instead of a plain finish image set in materials? For example, the grey horizontal pattern plaster on walls of below house as below image.image.png
Applying Materials to Surfaces using Paint Tool (one way to do it):
syman2000
If you want the siding to project shadow, you may want to look at wall sweep embedded into the wall profile.
Once you add those siding sweep, it will look like real siding and it will cast shadow.
Corsten.Au
Hello
Pick existing Roof material, you are looking for " bump" properties. which gives that texture..
Cheers
Pick existing Roof material, you are looking for " bump" properties. which gives that texture..Pick existing Roof material, you are looking for " bump" properties. which gives that texture..
Corsten
Building Designer
HeadbuttJ
Thank you. I checked your attached file, but where can I find your siding? The sweep in the material in grey out either in your file and mine.
syman2000
It is under profile
To add siding to wall, you have to choose section and then add sweep.
