How to create talus in revit (architecture)
NathalieKD
NathalieKD
I'm quite new with topography, but is there a way to easily model talus in revit architecture? I've seen some tutorials but only with specific tools that I don't have. I modelled some terraces but I need to smooth the cut between the terrace and topography (made from survey points).
I've been playing with "add points" but it doesn't seem like a very efficient method.
Thank you for your help!
Is it a flat slope? You could "Cut" that way with a sloped Building Pad. Then hide the Building Pad in the View.
Personally, I'd just create that "talus" by strategically placing Toposurface Points.  Point will snap to Ref. Planes, FWIW.
NathalieKD
No, it's not a flat slope, so I did add toposurface points. For now I'm not doing a complex landscape so it works perfect. Thank you!
