How to create small exterior steps that is on the same Level...?
pearlofsadness
Message 1 of 18
pearlofsadness
Hi all,
I have a question here, hopefully someone can help me out. Basically, I have 2 floors on the same level but of differing height (approximately 1200mm difference). Hence I would like to create a small step that will step downwards of 1200mm to another floor that is on the same level.
May I know how do I do it? As attached is a picture depicting my question:
Replies (17)
Message 2 of 18
In your case, you would enter 1200mm.
Message 3 of 18
pearlofsadness
err.....?
Message 4 of 18
huh?  you want the stairs to go up 1200mm, right?
Message 5 of 18
Create a 1200mm height stair. Uncheck end with riser.
Message 6 of 18
pearlofsadness
I did it but i can't seems to move the stairs. it got stuck in that position... 😞
Like it's flying mid-air:
Message 7 of 18
Change the base to the level below or the top the the level above (your case: Base offset = -1200, top level = none, stair height = 1200). Or go to an elevation, select the stair, move command, check Disjoin from the option bar, and you can move it vertically .
Message 8 of 18
pearlofsadness
Hi, Again 😞
Basically I did all and it works BUT Revit won't let me finish it, prompting this error:
Message 9 of 18
Your screenshot shows your Stairs going from Level 1 to Level 2. I though you said your Level 1 was two different Levels; one being 1200mm higher. If so, your Stairs should go from Level 1 to Level 1 with Top Offset at 1200mm.
Message 10 of 18
Stairs only go up.
Message 11 of 18
pearlofsadness
Oh that was a previous screenshot. I adjusted now 🙂
Message 12 of 18
It looks like it's more than 1200mm.  The end riser should be closer to the top surface.
Message 13 of 18
Don't move it when editing the stair. Do it outside when the stair is finished.
Message 14 of 18
pearlofsadness
Hi boys!
I managed to get the stairs done! Pheww!! Now it's just the railing that doesn't join properly!!! GRRR... I will try to figure that now!
Thanks guys! 😄 Here's a pic for update:
Message 15 of 18
Congrats.  Now work on that last Riser height. It's a red line waiting to happen.  If maxing out the Riser Heights doesn't do it, then you need another tread.  FWIW.
Message 16 of 18
georgehobel
learning stairs is fun... I would be nice if you could easily modify a stair rather than having to rebuild it though.
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 17 of 18
They can be modified fairly easily. Where do you have problems with?
Message 18 of 18
georgehobel
if i build a set of steps and want to adjust the number or risers, I'd like to be able to just ad one riser and have revit divide the rise and run to include the additional riser. it seems that Revit's way of adding the riser also changes the top of the stairway.  Clearly... i need to go play with my Legos a little more.
George Hobel
