How to create special floor using texture?
omar.amohamed
Message 1 of 12
omar.amohamed
I want to create a floor as shown in the picture. I know there is a way to do it using material but i don't know how to do it.
I want it to be transparent as shown in the picture. If anyone could post a video or steps about the creation of that floor, I will be grateful.
SPECIAL FLOOR 2.jfif
SPECIAL FLOOR.jfif
Replies (11)
Message 2 of 12
ennujozlagam
you can refer HERE. thanks
Message 3 of 12
omar.amohamed
Already Watched these videos. All of them taking about decorative floor, I am looking about the grating transparent floor.
Message 4 of 12
XXalessio.amodioXX
I have solved this issue applying a material.
I assign surface model pattern (eg grid 50x50) and apply transparency to the material. Works quite well because model pattern can be easily aligned
Message 5 of 12
syman2000
You can checkout this family.
https://www.bimobject.com/en-us/weland/product/entrance_grating_a22x22_frame_l30x30x3
Message 6 of 12
How about purple? I heard its pretty comfy.  😉
Message 7 of 12
omar.amohamed
Could you explain in more details?
Message 8 of 12
ahmadfiroozi000
You can use Model in place and select Floor, then create by Extrusion after that use void Extrusion and cut all holes
Message 9 of 12
XXalessio.amodioXX
here you have
Message 10 of 12
omar.amohamed
Excellent, Thank u
But in shaded view and render, I want it to be transparent. Is it possible?
Message 11 of 12
ahmadfiroozi000
This is Hatch so if the file export to other software for rendering maybe that doesn't show it.
Message 12 of 12
XXalessio.amodioXX
Hi, this a solution I have used for documenation purposes (e.g. Railing panel, Grid floors. Grid walls).
I do not perform Rendering.
If you want to render it you must model the exact volumetry.
For rendering purposes it is better to model the floor as one and prepare the 'Holes' as generic model floor based+array.
NB what I give you is JUST a suggestion (Good luck with it) beacuse I think it does not worth it.
Ussually those grids are provided directly  from producers and in documentation we must show only main grid division.
Hope it is clear
