Control Angular Dimensions with Reference Line
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
MCalza
565 Aufrufe, 2 Antworten
I need to make a family with an exemplary parameter of an angular dimension that allows modifying the angle between a reference plane and a reference line (with alignment constraint) to the extrusion.
What is desired is that it allows the extrusion to rotate at the angle entered in said exemplary parameter.
I have found this:
https://knowledge.autodesk.com/es/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018... htm.html
But I can't do the last 3.
The reference line created does behave Ok, but the extrusion does not move jointly with the line.
When Aligning and fixing the extrusion to the created reference line, errors are thrown.
Can somebody help me.
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: MCalza
Your link is dead. Do you have another?
If I understand correctly, you want to control Reference Lines' Angles relative to their Work Plane References. The key it the each Ref. Line needs to be Hosted (e.g. Associated ) to the Ref. Line it's being Angled from.
Open and inspect this Family I did for another member yesterday. Note the two Angle Parameters in the Family.
Nachricht 3 von 3
MCalza
als Antwort auf: barthbradley
Thank you for the reply @Anonymous
This is the correct link in english:
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit-LT/files/GUID-583BB09B-213A-47BD-84A8-8FC5BDABB953-htm.html
It's that I need, you understood it correctly. I have seen your Family and whit it I could solve the problem.
Furthermore I didn't know that I had to draw the extrusion in the same plane as the reference lines..
Thank you so much
