How to create sharp wall edge?
protsencko_mikhail
protsencko_mikhail
Hello! I want to know how to make two internal walls on the first picture combined in a sharp edge like on the second picture.
Thank you!
ennujozlagam
something like this?
click the vertical wall, drag the blue dot (disallow join) to edge of the circular wall?
Allow wall join.
protsencko_mikhail
it doesn't change anything, i've tried to do it to both
Lachlan-JWP
It's going to depend on the angle that the two walls join. The first image you showed has the first wall joining the second at a tangent. That will create a square edge as was shown in the image. The second image shows the two walls joining at more of an angle which created that sharp corner.
When you have the walls joining at the angle that you want use the wall join tool to cycle through the different join conditions until you get the one you want.
protsencko_mikhail
I've tried this tool but it doesn't go from tangent connection to an angle connection. Also, I used join geometry tool before using wall joins becouse otherwise wall joins tool would not work at all.
