How to create point with coordinates info in it?
wickedzik
Message 1 of 9
wickedzik
I just need to know how create a point marked with just number and to create schedule containing information in it like the coordinates and elevation of the points.
I have received a file from the consultant, but I cant figure it how they did it that way wihout using the Spot Coordinate command.
see attached screenshots.
Thanks for your help.
Replies (8)
Message 2 of 9
Post the file so we can see for ourselves instead of guessing.
Message 4 of 9
wickedzik
Hi Barthbaradley, its a large file. I have attached screenshots of it, I hope it can provide info visually.
Message 5 of 9
Why don't you just ask them how they did it?
Message 6 of 9
L.Maas
I probably would use Dynamo for that. Create a simple family with some location parameters. Use Dynamo to fill these parameters with values based on their position relative to an origin point (e.g a separate placed family, project base point or survey point).
Louis
Please mention Revit version, especially when uploading Revit files.
Message 7 of 9
andre.micka
This is the way I do it
Message 8 of 9
constantin.stroescu
this is quite easy to be done in AutoCAD but in Revit you'll need some workaround...
Here , you can see how I use to solve the problem in Revit:
Constantin Stroescu
Message 9 of 9
lim.wendy
Hi @wickedzik,
Thank you for submitting your question in our discussion forums.
Have you had a chance to look over the suggestions provided by our experts?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
