How to create new .pat files for revit filter wall ratings
sstattelman4GLLM
sstattelman4GLLM
I'm trying to create new patterns to use for revit filters for wall ratings but I'm not sure how to achieve what I'm looking for at the 45 degree angles. Any links to resources or thoughts on how to achieve this would be greatly appreciated. thanks!
Basam.Yousif
There are many tools that can help you with this. The most common solutions are:
1. If you have it in Acad, you can use the same pattern file (.PAT) since Revit can read it
2. Use pyRevit Addon. It's a free set of tools, including the very-popular Make Pattern Tool  https://www.youtube.com/watch?v=H7b8hjHbauE&t=97s
mari.shimode
Hi @sstattelman4GLLM, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you would like to receive more comments or ideas from the community, please let us know.
Mari Shimode
mari.shimode
Hi @sstattelman4GLLM, since I think @Basam.Yousif's reply is useful to the community, I have marked it as an accepted solution so others who have the same question can refer to it.
If you're still having the issue or have any other questions related to what you originally asked, please create a new topic with a link to this post included so the community can follow the conversation easily.
Mari Shimode
lucdoucet_msdl
Another good ressource is pattycake.io which allows for a finer control over the patterns using the low level coding.
hope this helps
-luc
