Hello all,
I am fairly new to Revit. I have made my own family of structural columns and beams which i would like to use for timber framing of our houses.
I just copied a Autodesk family and changed the dimensions of the timber. So far so good.
For the beams i can change the length by draging the blue triangle grips to the desired location which helps a lot!
For the studs i can not use the grips because the do not show when i select the stud. I can not figure out what is wrong with it. I have uploaded the file in this message...
