How to create multi sloped roof as an in place mass?
Prvoime
Prvoime
Something like this:
Multiple slopes, different heights...
If you start with a shape in floor plan, you can only add vertical edges to it, so you can't "cut out" the roof lines.
And if you start from elevation, and try to recreate the floor plan shape by selecting faces and "create form", you get "Unable to create form element" , and not being able to add edges anywhere, and have to plan 10 steps ahead to get the form (and I even could do it for this building).
In our projects we have to have volume of a building, but not exactly whole building - from the floor finishes, up to the roof, no facade insulation... Recreating it as a model in place mass seemed like the solution.
I made a simple example of what the end result should look like:
Replies (7)
You don't need a Mass to calculate Volume.  Use Rooms that compute Area and Volume will get you there.  Interested?
Example:
Spaces will work too.
...in fact, Spaces would probably be better.
Why mass?
lucdoucet_msdl
@Prvoime
For either interior or exterior volumes, I would propose two approaches:
A. Model a single inplace mass and create the slopes using the 3d editing tools  and boolean sections;
B. Model inplace mass and place one of a series of simple conceptual mass families with a parametric values for shed, gable and hip roofs. These would have parameters length, width, height to eave, roof slope instance parameters. Place and join to form a single composite volume that will report the total volume when scheduling and tagging the finished inplace mass.
Hope this helps,
-luc
Prvoime
@barthbradley
@ToanDN
I'm absolutely interested, if there's an easier way I'm all for it! I just don't know if it can be done the way we must do it. Rules and regulations in my country are very specific about it. Here's an image where I outlined some of them for volume boundaries.
Several things I don't know how to do:
- how do you set a space to go to the outer surface of the construction layer of the wall, not the insulation and other exterior layers?
- Same thing for the roof, you'd have to set the space some distance from the outer surface of the roof.
- Actually, how do you tell it to disregard all of the interior walls and other room bounding elements?
Help about spaces has several topics (how to set to level above, to ceiling, to roof...), but I didn't find anything this specific.
- Also, we actually have to have those schematic views, hatched and dimensioned plans and sections. As far as I can tell you can't dimension spaces.
There is a way to get there. You can use Room/Space Separation Lines in lieu of bounding geometry (e.g. Walls, etc.). You can create a Roof that is bounding and one that is not.  The one that is bounding will provide the upper limit of the Room/Space. You can hide this roof in the Views. Also, the Color Scheme can use whatever style and color of Fill Pattern you want.
...oops, didn't see step at floor. No big deal though. Again, you can always place bounding elements for defining Space/Room only - and then hide them in the View.
...not sure what you mean by: "you can't dimension spaces."
Simple.
- create a phase pre-existing
- create a view under this phase and set phase filter to show none
- draw room or space separation lines on the exterior wall finish
- copy paste aligned your roof and move it up so that the bottom of the
copy = top of the original roof
- add 3d room or space as suggested earlier
- set all separation lines and this roof to be demolished in existing phase
Done.
Prvoime
@ToanDN
Ooooh, pre existing! I actually thought of phases but was bothered that I'd have that schematic as my last phase, this clears that up.
@barthbradley
For dimensions, I thought you can't dimension to space borders in section, top of the roof for example. If I dimension to copied roof (as ToanDN suggested), but I guess that can be solved with a reference plane.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
