I am trying to figure out how to do floor finishes hatch for wet areas aka bathroom,
I tried to use split face and Paint under modify tab but it don't quite works.
Is there any solution to do this?
Gelöst! Gehe zur Lösung
Gelöst von jinergoh721. Gehe zur Lösung
Gelöst von se.ha. Gehe zur Lösung
Hi @jinergoh721,
we create different floor types for different floor finishes. For example Hardwood floor in the living- and bedrooms, tiles in the bathrooms. That makes it easier to apply materials (and therefor hatches), you can use it in schedules or create filters and graphic overrides.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
I just tried the way you mentioned in your Original Post:
Split Faces and apply Material to this face - works like a charm.
Split Faces | Revit 2022 | Autodesk Knowledge Network
Apply a Material to the Face of an Element | Revit 2022 | Autodesk Knowledge Network
se.ha
Apart from paint,
can go to <Remove paint>.
Then <EDITTYPE>, <FINISH MATERIAL>, <MATERIAL PATTERN> ,<SUFACE PATTERN>, for floor plan, <SELECT HATCHES>
So instead of applying paint just like change material browser, kinda..
Workshop C2 , wk8 2/05/2022
For personal reference, vague.
