How to create custom structural framing members?
Anonymous238
Anonymous238
I have a custom steel girder I need to replicate over a grid numerous times. I started with creating a >component >model in place >structural framing >model that looks perfect but I can not copy it. Is there a way to copy or do I need to make this thing all over again a different way?
Tom_Kunsman
Model in place families are always good for "one time use" cases, but if you need to use it in other projects then that is a different story.
You should be able to copy the In Place element, but I would almost recommend remakign the component as a structural framing member so you can use it in other projects.
Mike.FORM
It is probably not letting you copy it because it is using the grid it is currently at as a reference for and extrusion or ne of the modeled pieces within the model-in-place family.
Copy it first with ctrl+c, ctrl+v to disassociate it from the grid or uncheck the constrain and check disjoin if possible in the ribbon when using copy.
However, as @Tom_Kunsman said it is probably better to make this as an actual family. Copying a model-in-place family in a project duplicates the family in the project browser (makes it an entirely separate family). If you need to make a change later you would need to change every one of them individually.
