HOW TO CREATE CLIMATE ANALYSIS FOR AN URBAN AREA
Is it possible to generate climate graphics like (sun study, temperature, wind, rain, etc.) of an urban area generated in revit ? I was thinking that Insight 360 could help but I'm not so sure how to start and have already tried with flow but have problems to recognize the 3D model properly.. Any idea on how to create an accurate analysis?
Here I post an Image of the 3D model..Captura de pantalla 2018-09-08 11.23.30.png
ennujozlagam
hello, you can try to refer to this LINK. thanks
Corsten.Au
https://gbs.autodesk.com/GBS/
Corsten
Building Designer
loboarch
Revit is no t designed to do an analysis at this kind of scale.  The best thing might be Autodesk CFD or Flowdesign (I don't think that is available any longer?) You could also do this kind of thing in Ecotect (also discontinued). I can't think of anything that really do an energy analysis on this kind of scale.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Viveka_CD
@Anonymous
One suggestion is to break your site into smaller parts or zones (save them as separate files) and then try using Insight - High performance and sustainable building design analysis
Then you can combine the results in a program like excel.
