how to create boundary wall of house
Message 1 of 9
I wish to create the outer boundry wall to my house which is normally 3 feet tall. But when I try to draw it the minimum offset level is from ground floor to first floor.
How can I draw the outer boundry wall of the house which is 3' in height.
Accepted solutions (3)
Replies (8)
Message 2 of 9
ChrisNeedhamNZ
In the properties of the wall, change "Top Constraint" to "Unconnected," then set the "Unconnected height" to 3'.
Chris Needham
Whangarei
New Zealand
Message 3 of 9
ennujozlagam
@ChrisNeedhamNZ is right,
@Anonymous you can go to architecture > wall > wall:architectural and choose the type.
Message 4 of 9
RDAOU
@Anonymous
What do you mean by "Outer Boundary Wall" ?
  1. The Fence/Wall around the property line of the house? if YES, is the plot flat or sloped/variable topography?
  2. OR; some sort of retaining/foundation wall around and below the house?
Message 5 of 9
Walls around my garden and parking area which are normally 3 feet in height. When I tried to place the outside walls it was giving me minimum level of the first floor which is 10 feet. I cannot find a way to reduce the height to 3 feet.
Message 6 of 9
RDAOU
@Anonymous
Try to do it as in the following screencast
Message 7 of 9
Thank you so much. I have done it. I choose Basic wall, wall-site 215bwk for the boundry of my house. Is it normaly used for outer wall or I should choose another wall.
Message 8 of 9
Thanks you
Message 9 of 9
Thank you
