Problem - Not able to create straight grid in curtain system.
I am trying to generate a curtain system with a vertical/horizontal grid. But when I select the face (see attached), the grid alignes with one of the angled sides.
Is there any way to rotate this grid or directly aligned it with the vertical or horizontal sides??
Is this the face of a mass element? If so, does checking or unchecking the "Related to Mass" checkbox (in Properties) do anything for you?
Hi jherbst. Yes, this is a face of a mass element. I select the face of the mass element and the "Related to mass" checkbox is locked and cannot be checked/ unchecked.
rodrigo.bezerra
When you select the grid system, does a window like icon appear? If yes, use it to rotate the grid. Please click here and the suggested parent article in the link to find more about it.
Regards
Rodrigo Bezerra
@rodrigo.bezerra After selecting the "window" and rotating the angles, the Grid succesfully rotated.
Thanks!
