How to create a tee fitting of not 90 degree branch angle for pipe by Revit API?
When I use Revit ribbon drawing function, it is easy to create a tee fitting of any branch angle for pipe.
But when using NewTeeFitting method to do it, if the angle of branch is not 90 degree, then an InvalidOperationException throw.
I am sure the default fitting type is correct and the connector order is correct.  I have used the correct angle units.
You can reproduce it in any project. For example, you can use the default pipe and default tee fitting type , then you can reproduce it.
See issue in Revit API forum:
https://forums.autodesk.com/t5/revit-api-forum/how-to-create-a-tee-fitting-of-not-90-degree-branch-a...
How can I create a tee fitting of not 90 degree branch angle for pipe by Revit API?
Best Regards,
Zhangzg
Kimtaurus
This is the Ideas page. You need to post your questions on the forums.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
