How to create a Site plan with Project Base Point?
zzeerroo1234
Message 1 of 9
zzeerroo1234
Hello Autodesk..
I'm trying to figure out how to recreate the "Site" Plan that's shown below
2222.PNG I Tried to add it by going to Plan Views > Floor Plan and when i click "Ok" Nothing happens.. What am i doing wrong? Also i want to know how to add the Project Base Point to the Site Plan.
The Site plan already exists in this template..
I was wondering if this Site plan was deleted by mistake, How can i recreate it? I've searched every post regarding this subject on this forum but failed to find the solution i needed.
Basically on this Site plan i can see the project from above without any cut plan.. I only want to know how to recreate it to be exactly like this one.. Just in case i deleted it by mistake.
I'll provide the template file with this post hopefully you can help me out, Thanks in advance.
Arc_Template_NEW.rte [I couldn't attach the template directly to this post so i had to use Mediafire.]
(I didn't create this template)
Replies (8)
Message 2 of 9
I'm kinda lost. Are you trying  to start a brand new Project using the "Arc Template NEW.rte" Template, or trying to create a Plan View from a Level, which is what you are doing when you go to Plan Views > Floor Plan?
If the Site Plan already exists, you need to locate and open (or insert) the Project, which has an RVT extension.
Do this: Start a NEW Project and browse to and select the  "Arc Template NEW.rte" as the Template to use, then report back to us on what you see on the screen.
Message 3 of 9
Untick the box Do not duplicate.... in the dialog then you can choose a Level to create a Site plan.
Message 4 of 9
SteveKStafford
The dialog you were writing about for creating a new floor plan will filter out the levels that already have views associated with them. As @ToanDN suggested you just need to uncheck the option at the bottom to reveal the levels in the project.
Views are permanently associated with a Level. As such, the view called Site Plan (is a default view in most templates) ordinarily based on Level 1 (stock name). The base architectural template has a floor plan called Level 1, a ceiling plan for Level 1 and Site Plan. The primary and functional difference between Site Plan and the others is the View Range settings (cutting much higher than a floor or ceiling plan) and which categories are turned off.
A custom template might also be using custom Browser Organization, views that go missing will usually be listed under a branch with ??? which indicates Revit is missing information about the view to sort it properly. It looks like your image has all of the browser visible and I don't see any ??? but if there is more above what we can see in the image it's possible your view is just missing a sorting criteria to be listed properly.
Steve Stafford
Message 5 of 9
...and after creating a duplicate view from Level 1 to be named "Site Plan", go into the Visibility/Graphics dialog box for the view and manually turn on the Project Base Point and Survey Point under the Site Category.
Message 6 of 9
bin
You have 3 options:
1. Duplicate your Ground Level Floor Plan and set the View Range.  Also under VG setting, Rick Project Base Point under Site Category.
2. Create a plan view for the Ground Level under View Tab. You need to untick the option if you already have a floor plan associated to that level.  You still need to turn on the Project Base Point under VG setting.
3.  Duplicate a ground level floor plan, apply a site plan view template to it.
Message 7 of 9
zzeerroo1234
Thanks to all of you who replied with a possible solution!
I'll make sure to give them all a try by tonight.
Message 8 of 9
zzeerroo1234
I'm sorry for not making it clear.. I just have some difficulty explaining what i really need.
I'm trying to recreate the site plan just in case i deleted it by mistake so i can be able to make it again.
Tonight ill try some of the solutions posted on this forum.
Thank you for your reply.
Message 9 of 9
I get it now. You explained it right. I went left.  My misunderstanding.  No biggie.
Good luck.
